Just wondering what the "file index mode" means in the Pilot app on the P3? You have two options, either reset or continuous.
I do formatt after every flight and it starts over at 0001- but then I am downloading the same file numbers time and time again- messing me up trying to sort them all --any suggestions Thanks
Put the files from each flight in a different folder and you will have no problem with file names clashing.I do formatt after every flight and it starts over at 0001- but then I am downloading the same file numbers time and time again- messing me up trying to sort them all --any suggestions Thanks
Check that you have the latest version of the app.I do formatt after every flight and it starts over at 0001- but then I am downloading the same file numbers time and time again- messing me up trying to sort them all --any suggestions Thanks
It's not each power up. Files will be in sequence across power ups but once deleted off the SD card (or a fresh SD card inserted) it will then reset the counter to 0001.It refers to the photo/video numbering system, in reset mode it resets to 001 after each power up, in continuous it starts at 001 and just goes up without a reset.
I'm quite dubious about this suggestion.You should not really do a format very often as you will electronically wear out the memory, its best wait until it almost gets full to do a format.
I've never heard it before but I've read the opposite from dozens of credible sources.
Here are just a couple for example:
http://au.lexar.com/content/lexar-memory-card-tips
http://photo.stackexchange.com/questions/1988/how-often-should-memory-cards-be-formatted
http://digital-photography-school.com/8-tips-for-maintaining-your-memory-card/
http://forum.nikonrumors.com/discussion/1302/format-memory-cards-or-delete-images/p1
http://petapixel.com/2012/03/07/keeping-your-memory-cards-healthy/
But ... Almost all modern memory cards can withstand at least 100,000 Program/Erase Cycles, and some cards can withstand as many as 10 times more cycles than standard cards.The sd cards are flash memory and have a finite life of x amount of write cycles.
Thanks, good to know, my Lumix creates a new folder each day and starts over from 0000, or just sequences up across folders.It's not each power up. Files will be in sequence across power ups but once deleted off the SD card (or a fresh SD card inserted) it will then reset the counter to 0001.
