What fails first - 5.8GHz control or 2.4GHz feed?
Discussion in 'Phantom 2 Vision Discussion' started by gpauk, Apr 12, 2014.
  1. gpauk
    Aberdeenshire, Scotland
    There's been lots of talk on this -- but I thought it'd be interesting to summarise everyone's results, and see what variation there is...
    So - stock P2V, before you mod it, which craps out first, the video / telemetry 2.4GHz feed or do you get a clear "control signal lost" message in the video stream first?!
    So -- for me, before mods, the 5.8GHz control feed always failed first.
    What about everyone else?
  2. rfernandez
    2.4 ghz video feed will go out first.
  3. GhostMaster
    Yes 5.8ghz fails first...
  4. Meluk
    Manchester
    Guess it depends a lot on on the flying environment. 2.4 will penetrate obstructions better than 5.8. If there are any obstructions for example.
  5. Madwak
    Depends whether you are using CE mode or FCC mode on the controller.
  6. gpauk
    Well, I assume everyone is using FCC mode... :)
    True... But if you are flying line of sight - in in sight! - that will not be very important.
    5.8GHz will also suffer more attenuation in damp air.
    However, most folk that I've noticed commenting, seem to have the 2.4 drop out first. Hence asking the question!
  7. skyhighdiver
    South Dakota
    I always had 2.4 wifi video drop out around 800-1000ft before my fpvlr 1/2 dome my control has always been good out to min of 4000ft Got 1.1 miles the other day with 5.8 control though
  8. nhoover
    Los Gatos, California
    2.4 pretty much always failed first for me. So I added antennas to the repeater and have had fpv working to up to 7000'. But I've had the 5.8 work out to a max of well over 9000'.
  9. phantomguy
    For a STOCK unit, I believe DJI has the Video feed distance formally rated at much less distance than the transmitter/control distance.
  10. FlyingFox
    Cheshire UK
    My video feed used to drop out always before at about 500-900' I hVe a better antenna on now and it now drops at about 1500-1700' my tx still hasn't gone to fail safe, I've no idea how far it will go.
Similar Threads - fails 8GHz control Forum Date
Return to Home Fails on my LEMON 4 PRO Phantom 4 Pro Help Jan 5, 2018
SD card reformat intermittently fails Pro/Adv Discussion Dec 21, 2017
Controller Calibration Fails Mid-flight ... Pro/Adv Discussion Dec 3, 2017
Phantom 4 Controller fails to charge Phantom 4 Help Nov 11, 2017
P4P - Failsafe RTH reverse route Phantom 4 Pro Help Nov 9, 2017
