Curious what these functions do?
Triple rate controls
Auto Yaw trim
Auto yaw
Can I set these up on a Taranis?
Auto Yaw trim
Auto yaw
Khudson7 said:Well I am not sure but I am guessing that these are not already on the Futaba T8FG, but that, someone has programmed some of the switches or knobs on the Futaba to do these things. I would bet that it COULD be done on the Taranis but I do not understand what it is they do, from your question. Perhaps Mike could help here.
Khudson7 said:Yes, I would be curious too, as to what they do as I might like to consider that functionality for the taranis. Hopefully one of the Futaba users, can chime in and answer this.
Just one side note that you may already be aware of, but I wasn't until recently when I was trying to duplicate a function that a futaba user did. It has to do with setting curves and expos...when on the futaba you set an expo of say -50% to soften the stick movement at the center, to dupe that on the taranis you need to set expo to +50%. Seems that Futaba and FrSky went in different directions regarding these settings.
As I said, you may already be aware of this, but just thought I would pass it on, in case you were not.
quality control said:Khudson7 said:Yes, I would be curious too, as to what they do as I might like to consider that functionality for the taranis. Hopefully one of the Futaba users, can chime in and answer this.
I wasn't at all. Do you soften your sticks? I would like to learn more.
Khudson7 said:I have a 3 way switch(in my case I used sb, but any one could do it) that adds more exponential to the rudder for when I want to video and with yaw turns in particular. Just in case you are not familiar with expo, when adding more expo, the stick movement from center will start its movement of the phantom more slowly and then get faster as you get toward the end of its movement. So by having the rudder stick less sensitive at the center, meaning you have to push the stick further to get the same movement as before, it gives you the ability to better control the turns with the rudder when doing yaw turns. So for example, on my input(sticks) screen, for the rudder, UP on the sb switch, treats the rudder movement normally(evenly increase the power from center to end), MIDDLE sb switch changes the weight of rudder to 75% and adds 65% expo, and lower switch drops rudder weight to 50% with 65% expo AND also changes the weight of elevator and aileron to 90% and add 65% expo. These are all my personal preferences settings and it helps me with getting smoother video with my fat and awkward fingers on the sticks with turning the camera.
Hope this helps and makes sense.
DesertFlyer53 said:I have the Futaba T8FG. A while ago iamwood started a thread on this transmitter. That thread is the main reason I bought my Futaba. ianwood shared his profile which is now at v5 after several changes/updates. I am not familiar with the Taranis radio so I don't know if these functions would work on that raido. See the link below to ianwood's Futaba thread...
http://www.phantompilots.com/viewtopic.php?f=19&t=8358
Incidentally... the Futaba transmitter works with the stock DJI Phantom receiver, which is the way I use mine. Just bind the Futaba to the P2 receiver and you're good to go after calibrating in the assistant. Same range if not better.
quality control said:DesertFlyer53 said:I have the Futaba T8FG. A while ago iamwood started a thread on this transmitter. That thread is the main reason I bought my Futaba. ianwood shared his profile which is now at v5 after several changes/updates. I am not familiar with the Taranis radio so I don't know if these functions would work on that raido. See the link below to ianwood's Futaba thread...
What do the functions I have outlined do? I saw that thread and that is where I got my question from
DesertFlyer53 said:quality control said:DesertFlyer53 said:I have the Futaba T8FG. A while ago iamwood started a thread on this transmitter. That thread is the main reason I bought my Futaba. ianwood shared his profile which is now at v5 after several changes/updates. I am not familiar with the Taranis radio so I don't know if these functions would work on that raido. See the link below to ianwood's Futaba thread...
I don't think I can explain it any better that how it was explained in that thread. Sorry, you're going to have to be more specific.
DesertFlyer53 said:Below is a copy and paste from the first page of that thread. #3 explains the tripe rate function and #6 explains there auto yaw...
"The Transmitter
This is where the installation is different from the other models. Profiles are model specific. I have built a model for the P2 on my 8FGS which provides the following capabilities:
1. All the basic flight controls of the stock P2 transmitter including similarly positioned "S1" and "S2" switches.
2. A timer that starts when you take off and stops when you shut the motors off. It will beep every minute and then a series of beeps will occur after 15 minutes to remind you to check your battery condition.
3. Triple rate flight controls on SB set up to help with filming especially reducing yaw sensitivity:
UP: full linear controls. (Note: The UP position is away from you.)
MIDDLE: YAW 75% -35 expo, PITCH 100% -25 expo, ROLL 100% -25 expo.
DOWN: YAW 75% -50 expo, PITCH 90% -35 expo, ROLL 90% -35 expo.
4. Smooth gimbal control. The SC 3-way switch will move the gimbal from its current position smoothly up or down depending on position.
5. Forced fail-safe. Switch SF will force the Naza into failsafe mode regardless of mode switch position.
6. Auto YAW on SE and LD.
DOWN: Off.
MIDDLE: YAW based on LD trim.
UP: YAW and ROLL based on LD trim (circle around an object)."
Khudson7 said:Now the one thing I was not understanding before but I believe I do now, was what he was doing with the auto yaw and auto yaw trim functionality and how it is used. And I am impressed and it sounds like a pretty clever way to better control yaw moves and yaw moves with a little roll to circle objects.
PhantomPhreak said:It works great for turning on a point. You are not using sticks for the maneuver, you are using the left rotary dial LD (Yaw Trim) When the SE switch is set to Yaw and Roll it adjusts the trim for both in equal amounts. Increasing the trim more yaw and roll tightens the circle. Rotating to the left results in a clockwise rotation, to the right CCW.
OI Photography said:Khudson7 said:Now the one thing I was not understanding before but I believe I do now, was what he was doing with the auto yaw and auto yaw trim functionality and how it is used. And I am impressed and it sounds like a pretty clever way to better control yaw moves and yaw moves with a little roll to circle objects.
Ditto, and I've been playing with it in my mind since I saw DesertFlyer's post above, trying to figure out the best way to achieve it. I'm trying to decide it if would be better on the LS or one of the knobs, probably the latter. Very interested to see how your testing goes.
I guess the trick is finding the right roll/yaw ratio to output.
