What counts as spying?
Discussion in 'Standard/4k Discussion' started by riverphantom3, Dec 28, 2015.
  1. riverphantom3
    North Carolina
    I've have flew over a few houses and hovered above a few, does this count as spying?
  2. flybid
    I don't know if there is a technical definition. In my opinion, if you're at low altitude above someone's house and you're hovering, you're spying. If you're at higher altitude (say 300' or more) and moving along, even at slower speed, you're not spying. Just my opinion.
  3. riverphantom3
    North Carolina
    So there isn't a said law of what counts as spying, just that it is illegal?
  4. N017RW
    Palm Beach Co.- FL
    It's referred to surveillance and many argue it is unclear as to what specifically constitutes this but if you are purposely fixated on a subject without permission, that's a good start.
  5. riverphantom3
    North Carolina
    Well what determines if i'm purposely fixated on a subject?
  6. N017RW
    Palm Beach Co.- FL
    Phantom Pilots is a great resource for Phantom related topics.
    As I have demonstrated it is not so good for Legal advice.
  7. riverphantom3
    North Carolina
    Lol thanks anyway, just fly high enough they can't tell where the drone is
  8. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    Just avoid people & property below where you fly. Neighborhoods are never a good place to fly. Find a field, sports field or park.
    joeb1999 likes this.
  9. joeb1999
    Not spying. But if your neighbors request that you not fly above them I'd respect it and just take it elsewhere to use. Technically your not supposed to fly over them anyway. Or directly above them.
    use of a drones co
  10. barefootbeachcombing
    US
    Recreational Users | Know Before You Fly
    What are the safety guidelines for sUAS recreational users?
    • Follow community-based safety guidelines, as developed by organizations such as the Academy of Model Aeronautics (AMA).
    • Fly no higher than 400 feet and remain below any surrounding obstacles when possible.
    • Keep your sUAS in eyesight at all times, and use an observer to assist if needed.
    • Remain well clear of and do not interfere with manned aircraft operations, and you must see and avoid other aircraft and obstacles at all times.
    • Do not intentionally fly over unprotected persons or moving vehicles, and remain at least 25 feet away from individuals and vulnerable property.
    • Contact the airport or control tower before flying within five miles of an airport.
    • Fly no closer than two nautical miles from a heliport with a published instrument flight procedure.
    • Do not fly in adverse weather conditions such as in high winds or reduced visibility.
    • Do not fly under the influence of alcohol or drugs.
    • Ensure the operating environment is safe and that the operator is competent and proficient in the operation of the sUAS.
    • Do not fly near or over sensitive infrastructure or property such as power stations, water treatment facilities, correctional facilities, heavily traveled roadways, government facilities, etc.
    • Check and follow all local laws and ordinances before flying over private property.
    • Do not conduct surveillance or photograph persons in areas where there is an expectation of privacy without the individual’s permission (see AMA’s privacy policy).
  11. tcope
    Salt Lake City, UT
    I think you are mixing spying with "surveillance". If you mean surveillance than this usually only applies to law enforcement. Surveillance then means that you observe someone enough to know their movements and habits.
    The main difference is if you can show that you are filming a large area or many people and not one person, you are fine.
  12. Jay H
    Long Island, New York
    Unfortunately OP has violated most of those safety guidelines in the last day including flying at 1000 ft altitude, almost hitting a plane, flying/ hovering over other peoples houses. I really, really hope the kid doesn't end up hurting someone or take down a plane/helicopter.
    Also here is a test done with an inspire about spying.
    #12 Jay H, Dec 28, 2015
  13. fordruid
    Wisconsin
    It is what THEY perceive that you are doing. From there you will need to prove that you didn't do it, very hard to do. Just flying by, probably ok. Hovering 12 ft above that 14 yr old in a bikini 'cause you had to sneeze', not so much. Anything in between is judged by their paranoia
  14. barefootbeachcombing
    US
    Yep. That was my first and will be my only reply to the OP after everything he has posted on the forum.
    Jay H likes this.
  15. Mikebike
    Western Kentucky
    If you are too stupid to know if what you are doing could be construed as spying then find another hobby.
  16. barefootbeachcombing
    US
    Too immature to know the difference it would appear.
  17. N017RW
    Palm Beach Co.- FL
    The video is subjective.
    Naive even.
    Secrecy notwithstanding, there is equipment available to easily allow ID imaging in the demo-ed conditions.
  18. Jay H
    Ok, clearly the video isn't extensive test, its just some guy showing examples of how stupid it would be to spy with a drone. I highly doubt this 14 year old kid is going to get equipment for ID imaging.
    #18 Jay H, Dec 28, 2015
Similar Threads - counts spying Forum Date
DJI accounts using two different email addresses. Is this true? General Discussion Jun 9, 2017
Multiple accounts/ users using DJI Go app... Control (Go, Litchi, etc..) Mar 21, 2017
Go Professional coupons/ discounts? General Discussion Jan 11, 2017
any good promo codes or discounts Phantom 4 Discussion Dec 14, 2016
Are y'all aware that DJI offers educational discounts? Has anyone gotten this coupon to work though? General Discussion Dec 7, 2016
