What are your limits & "Line of sight"
Discussion in 'General Discussion' started by jamespb78, Feb 23, 2016.
  1. jamespb78
    So a couple of questions....
    1) I've read lots about only flying "line of sight". Does that mean: A) make sure I can see the drone at all times? or B) make sure the drone has a direct line to me at all times, even though I may not be able to see it? My eyesight is OK, but I find that once it's 50 metres away...I can't see it, so I'm then flying by using the iPad screen/FPV.
    2) What is considered a safe distance limit? I know thats an open ended question, but in a country environment, no people, no interference, what is a safe distance? On the weekend I flew 1000 metres away from me, and had an altitude of 120 metres - this was with my phantom 3 advanced.
  2. fordruid
    Wisconsin
    1. los is b, vlos is a. FAA wants vlos
    2. 1,000,000 different opinions on this, my feeling is what I feel at each location will not endanger others if it fails. Know the area that you are flying, even if by maps and google earth
    JBJO likes this.
  3. flpholt
    palm harbor florida
    a is the right answer as far as distance well that's up to you to decide if you want to fly out of sight
  4. Air Ontario
    U.S./ Canada
    The FAA and Transport Canada, lean towards a visual line of sight with the unaided eye. So as far as one can see the bird in flight and avoid any collision.
  5. jamespb78
    Thanks for the replies.
    Not wanting to start an argument, but the vast majority of drone videos I watch on Youtube, they would have to be out of sight of the operator - based on how far they have travelled. Still, that does not make it right, but it's interesting so many people do indeed fly it out of sight.
  6. Air Ontario
    U.S./ Canada
    I know.
    It can be done safely though even at lower than 200 ft. alt. but common sense needs to be present.
    However people will do as they please when they please in a free and democratic society.
    Some of us are blessed with miles of wilderness, frozen lakes and sparse population.
    NepenthesLucas likes this.
  7. jamespb78
    Yes, I'm very lucky where I am. Out in the country, minimal houses, just lots of open paddocks and a lake - which is why I wanted to push the distance...to get to the other side of the lake! (About 1500metres)
  8. Air Ontario
    U.S./ Canada
    My first real flight (other than hover testing, etc.)was 1300 m over/across a frozen lake. No real issues other than some trees 6-8 ft in front of me scattering the signal. It did make me turn around however.
  9. ladykate
    Bellevue, NE
    I've done a bit of testing - and it would only apply to me - but VLOS (the important part) for me is 280 meters with a Phantom on a clear day in sunlight. I just can't see it much farther. If I knew someone was watching, I would probably fly well within that. ;-}
  10. dirtybum
    Fly it how you want to while you can, i fly most everyday weather permitting, i can count on one hand how many times someones even seen my white bird
    Mark The Droner likes this.
  11. Mark The Droner
    Me too. In fact, I can count on one hand how many birds I've seen besides my own (none).
  12. BillH
    Same with me. I would rather fly with nobody observing. I guess I just don't want the drama it creates with some people thinking they're being spied on or the government is watching them. I've already had one guy say he would shoot it down and he's never seen it.
  13. azpilot61
    Arizona
    200' or lower on the Height and about 1500' out is as far as I need to go.
  14. flpholt
    palm harbor florida
    396 height 2600 feet distance easy to see
  15. Air Ontario
    U.S./ Canada
    I did a Litchi mission yesterday( so I knew where the drone was going/path)however with the southern sky background and the sun to the right, I was able to easily see it flying @550m when it made it's programed turn.
    I agree they can be hard to see, I took my eyes off mine when a hawk got near the drone and I had trouble finding it afterwards at about 300 m.
    It truly is an individual dependent distance.
  16. silvertonesx24
    To add, I'm curious as to what is considered a responsible altitude limit to most. Obviously, not considering being around major urban areas or within 5mi of any airports.
    I have never been higher than 750ft. Was flying in an ex-urban/rural area.
  17. Dave from Ok
    I'm an old radio guy, and to me, line of sight does not mean visual. When the FCC talks about LOS communications, (and there is plenty they talk about)it simply means "clear of obstructions" it may be 20 miles....People that says the FAA "leans toward" VLOS, what are they basing that on?? They say line of sight,,,ok, I have a telescope, now what? "Unaided line of sight"?? LOS means you are far less likely to lose comms, and far more likely to reestablish them,,,if there are no buildings or mountains between you and your bird. And that is safer.....
    kphantom, Jussaguy and dirtybum like this.
  18. fordruid
    Wisconsin
    #18 fordruid, Feb 24, 2016
  19. nhoover
    Los Gatos, California
    It's going to be different for different people depending on your eyesight and you can't use magnifying lenses, just "normal glasses". I can see it at 2500' on a good day. My son (early twenties with the awesome vision I used to have) can see it at 3500' and even further.
  20. Air Ontario
    U.S./ Canada
    Their FAA official interpretation of visual line of sight.
Similar Threads - limits Line sight Forum Date
Flight altitude & distance limits Standard/4k Discussion Jul 16, 2017
Firmware Update Limits Range Phantom 4 Pro Help Jul 1, 2017
P4 Firmware New firmware limits range and altitude? Firmware Jun 8, 2017
Altitude limits Phantom 4 Pro Discussion Apr 26, 2017
For this i pushed my Phantom 4 to the Limits (3200Meters Altitude) Photography and Film Mar 24, 2017
