Yip p3s was and still is good one,mine over 3years and apart from odd wifi breakup still goes very well today,did drop remote and broke anttena but easy fix,great bird
You would probably get more responses in the Standard forum than here in the Pro/Adv forum. Just a thought.
Windsurfer does not guarantee constant wifi connectivity. it only extend the range a little bit. I have a standard as well and the most common issue is the limited range, although saw some threads where people claiming over 12,000 feet in open space and in the country side where there is not wifi interference. The most I got further is close to 3000 feet.WiFi break up seems like pretty normal in here. Dont you have a windsurfer?
P3S came out in Aug 2015Yip p3s was and still is good one,mine over 3years ...
Windsurfer only works on 5.8GHz control antenna ... has nothing to do with 2.4 ...
Nigel
Thanks i check docket feb 2016P3S came out in Aug 2015
Signal loss if you go too far.Hii guys, What are the common problems with Phantom 3 standard faced by people everyday? Tell us your experiences. Is P3S a reliable aircraft? Thank you!!!
