Weird one
Hi guys, tried to use my p3a today for the first time in 3 weeks. I set it up on my launch pad and when I started the props they revved up as normal on start up but didn't go to tickover. They stayed revving quite hard. I stopped them straight away and re started them several times before they would tick over. Also the camera gimbal was not straightening out on start up. It did eventually after I flicked the vertical adjust switch on the back of the controller. I did fly for a minute or so but the wind was gusty and it wouldn't settle into a comfortable hover so I packed up..... Any ideas?? Was it just to windy or does the not settling to idle mean there's trouble ahead?
What exactly do you mean by tick over?
Reactions: Pharm
When you start the props they rev up twice then settle at a slow speed before you power up to take off. They didn't settle to that slow "tickover" speed they stayed running at a fast speed... After several re starts they did do the normal start up routine, but by which time I was rather concerned about flying.
have you tried re-loading the firmware.... could be a corrupt file somewhere causing that to happen
cokersean20
