Weight vs flight time
Discussion in 'Pro/Adv Discussion' started by Danielmexortega, Jan 8, 2016.
  1. Danielmexortega
    Hey guys, I wanted to see if I could calculate how much weight I can add and how much of a difference that will make in terms of flight time.
    Just so that when I'am adding stuff I have a good idea of how it's gonna affect my flying time. Let me know if this makes sense.
    - Weight of p3p including battery and propellers is 1280 grams
    flight time is 20 min = 1280 seconds ( you can change this number to actual flying time)
    divide weight (1280) by time (1200) = 1.06
    So this means for every 1.06 grams I add to my drone it will reduce my flying time by a second.
    Right ? Or does this not work.
  2. syotr
    1 gram per second is a ballpark figure that many have been using for some time. Be aware that it is not linear, though. As you continue to add weight, at some point it will not lift off at all and your flight time will be zero. Long before that, it would become a pig in the air.
  3. Waylander
    West Yorkshire, UK
    Good theory.... but I think the "Square Law" applies here somewhere.. I'm not a physicist, but something like this.. "To double your speed through the air you have to quadrupole your power", I'm sure the boffin's out there will advise better.
    Waylander
  4. Danielmexortega
    I believe the square law applies to light and how a beam widens from the source. I'am no physicist by any means, I was hoping there was one amongst us that could chime in.
  5. Danielmexortega
    I wasn't aware of this one gram per second being a "thing" I'am pretty new to the drone world. thanks for your input.
  6. Waylander
    West Yorkshire, UK
    I believe the principle ( I said "square Law" to be brief, I meant the "inverse Square Law" ) applies to many things, here is an example of what I meant:- Wind resistance and cycling speed • Dave McCraw
    It might be that I'm talking rot, but like I said I'm no physicist :)
    Waylander
  7. Danielmexortega
    I see what you are saying.
  8. Raggitash
    Scottish Highlands
    Hi Lads,
    Ye just might be lookin fer this?
    Power-to-weight ratio - Wikipedia, the free encyclopedia
    The bits yer lookin fer are in thae middle an doon the bottom.
    Its maer or less whit Waylander said, nae really richt oan the button but clase enough.
    Dinna ask me any mare ave ah sair heed just lookin at it.
    Raggi
  9. happydays
    Warrenpoint, Ireland
    Aha! Someone who actually speaks Ulster-Scots!
Similar Threads - Weight flight Forum Date
Weight Affecting in Flight Performance Phantom 4 Pro Discussion Jul 31, 2017
POLL: flight time / weight in grams General Discussion Sep 5, 2014
GS added weight and flight time? DJI Ground Station Jul 9, 2014
Math Equation of Flight Time VS Weight.. Phantom 2 Vision Discussion Apr 23, 2014
How critical is the P2's 1.3 kg weight limit re safe flight? Phantom 2 Discussion Mar 23, 2014
