Weather
Discussion in 'Pro/Adv Discussion' started by clue3030, Dec 31, 2015.
  1. clue3030
    I was wondering what is the lowest temp I can fly in? I have a windchill of 16 degree Fahrenheit. The reg temp it's 37 degrees. Need advice.
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The Phantom manual suggests not flying when it's below freezing. That's good advice considering the batteries won't work as well when it's that cold out. Your hands will freeze too :)
  3. Oso
    Oso
    Western US
    #3 Oso, Dec 31, 2015
  4. Thunderbyte
    Windchill does not change the temperature of objects, only people, animals etc. If its 37 degrees outside with a windchill of 16 degrees the temperature for your drone is 37 degrees.
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Right. I'm referring to the actual temperature above (FYI).
  6. MapMaker53
    Long Island, NY
    Another concern would be the tablet LCD freezing if in the cold for an extended period of time. We've had people in the field who have had tablet screens fail while working in cold weather - though you probably wouldn't be outside all day like our field people. I'd recommend a pair of touchpad gloves that allow you to operate the screen.
    I've considered tossing one of those chemical hand-warmer paks into my drone case to keep the batteries nice and toasty between flights, but I've never tried one and don't know how hot they get. Wouldn't want to melt the foam in my case.
  7. THG Aviation
    If you've got wind chill of 16 degrees at 37 degrees F I'd worry more about the wind than the chill.
  8. ScatSpeak
    MO, USA
    I flew today with the temp at 34F and "feels like" 24F.... even with good gloves, I decided to stop before my P3 or batteries needed too.... but up to that point it was a typical flight... YMMV but don't let the cooler temps stop you, the P3 can tolerate it as long as you can if you're out in the elements too... do remember that the temp at higher altitude with more wind may be colder than where you're standing.
  9. Bigskyflyer
    SW Montana
    I flew this morning at -2 F. Flew 3 batteries and no issues. If you can take it the p3 can. Just keep your batteries warm until it is time to fly.
  10. Mark The Droner
    No experience but...
    Although the manual recommends not flying below freezing, there are countless posts on this site from experienced UAV pilots in places like Alaska that fly at 0 degrees F and insist they have no problems. So I'd consider it a judgment call on your part.
  11. MapMaker53
    Long Island, NY
    And just as a side note.. If you are flying in a climate that has snow on the ground and your bird decides to auto land because it runs out of juice, a white Phantom on the white ground might be difficult to spot.
Similar Threads - Weather Forum Date
For those studying for part 107 - Weather General Discussion Jul 31, 2017
Website for weather conditions to fly drone Off Topic Jul 30, 2017
Hot weather phantom in car Phantom 4 Discussion Jun 12, 2017
Why is sky all white in sunny weather? Photos and Video Apr 20, 2017
YES! Good weather in the UK!!! Phantom 4 Discussion Mar 25, 2017
