The p3a shows it can travel 2km but when i take it uo for a range test i get weak signal at .5 miles or even 300m distance which isnt very far. I really want to fly it out but i an afraid of the weak signal and may not see the fpv view. Help!!
I was at about 150m high and only 300m distanceWhat way are your antennae pointing? What height are you flying at? Urban or countryside? Any trees in the way? Need so much more to determine if there is an issue. I was at 1650m distance today in open country at 70m. That's over a mile.
It's common to have a weak signal right above your head if your antennas are vertical. Picture yourself in the center of a donut 1mi in diameter but the donut hole is 1ft diameter. The shape of the donut is kinda how the radio waves go out and come back, from the controller and from the P3. The center of the donut has little signal directly above and below the sources.I got a weak signal while flying today. I was hovering above my head at about 330 feet. Trees are pretty far away from my location. Never got that warning before the update. I'll keep an eye on it and report back.
Makes it tough to do spherical panoramas directly overhead, especially when in the middle of a 20 shot sequence, the bird starts a RTH by descending in place, and you have to cancel it, and then return to the original altitude and start all over. Rinse and repeat!Had same issue tonight glad I found this thread. Guess we cannot stand right under the bird
