  1. jerzydawg
    Hey guys,
    I am running tests to see how far the drone can go from my house but as soon as I get .2 miles away or so, it starts staying "Weak RC Signal". If the signal gets lost, does the drone automatically fly back home or what is the exact process?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    If you're running the default DJI GO settings, your Phantom will return to the home point when the remote controller signal is lost (as long as it's connected to 6+ satellites). You can also make it hover in place or land at its current location.
  3. jerzydawg
    How do you avoid it from landing in the current location in this case? That is the only thing I would not want it to do.
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Make sure this setting is set to "Return-to-Home" (the default setting):
  5. jerzydawg
    Great, thanks. Is the Smart Return Home the ability for it to come back once battery is too low?
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    When Smart Return Home is enabled, your Phantom will monitor the battery level and try to auto return home before the battery is at a level where your Phantom would not be able to make it back. The DJI GO app will notify you before it starts returning home. At that point, you can either let it come back or cancel the RTH.
    KevMo Photog likes this.
  7. NorthcountySD
    North County San Diego
    Thanks msinger although it is all there in the manual it's always good to hear the confirmation!
  8. snabie
    amsterdam
    What about some people stating better to disable the Smart Return Home option?
  9. msinger
    Approved Vendor
    Harrisburg, PA (US)
    There's no harm in keeping it enabled. If you decide to disable it, you just need to make sure you have enough battery power to get back to the home point -- since the DJI GO app will no longer remind you.
Similar Threads - Weak Signal question Forum Date
Weak Remote Signal "solution" + Questions Standard/4k Discussion Dec 11, 2015
Weak image transmission signal Phantom 4 Help Aug 9, 2017
Need some help: Remote controller signal weak. Standard/4k Discussion Aug 6, 2017
Advanced Remote Controller Weak Signal Phantom 3 Help Jul 23, 2017
Standard P3S Weak/Lost Video Signal Phantom 3 Help Jul 15, 2017
