Hi all, i had received a 3s 5200 lipo 10c with a weak cell ( about 0.15 v less the other), there is any remedy or try i can do to repair it?
Sorry for my english, i would appreciate any suggestion thanks.
Thanks for the very good news, however i will give a try with your technique... Unfortubately i had purchased another same battery some days ago...
I am sure the second one will be perfect.
It is not possible to be always unlucky!!
Are you measuring the voltage using the battery charger or a voltage meter? Because if you use the battery charger, the difference can be caused by a not calibrated battery charger measuring circuit.
So I suggest you to compare the battery charger voltage cell reading with a reading done with a voltage meter directly on the battery balance connector.
