Water Damage - Camera issue now
Discussion in 'General Discussion' started by Stephen Weinberg, Jun 5, 2016.
  1. Stephen Weinberg
    I crashed my Phantom 3 Advanced into my brothers pool over the weekend. I dried it in the sun used the rice trick and everything seems to be OK with the exception of the camera. The video transmission is now very poor and the controller loses the video connection.
    The question is where is the problem? With the camera / gimbal assembly or is this a problem with the ESC? I am going to put the camera assembly back in a bag with some silica gel (dessicant) I purchased - but I am afraid the damage may already be done.
    Any suggestions?
  2. 0DRK3RT
    The problem is your Lightbridge module is shot. It's located inside the VPS box behind your gimbal.
  3. Stephen Weinberg
    How difficult is it to replace the Lightbridge module? So pissed!
  4. Mako79
    Sydney Australia
    Its not hard provided you remember where all the screws and the correct antennas to plug back in. Just tag number the antennas first before unplugging (there are 4).
  5. Stephen Weinberg
    As long as there is no soldering it should not be too tough. Is it the board underneath the drone - with the vision positioning module? OR is it inside?
  6. Stephen Weinberg
    Also - is the Lightbridge module the same as the OFDM Module.
  7. 0DRK3RT
    It's INSIDE the little box that hangs under the drone with the little screen sensors (VPS) on it. There was a video someone posted on here who took it apart to confirm Lightbridge was in fact inside it. It looked like a rather complicated disassembly process.
  8. 0DRK3RT
    No idea
  9. Reed L
    Alta, Ca.
    Could also be that one of the ribbon cables got pulled from it's socket by the force of the water. You will need to pull the camera mount safety pins to check the 2 cables but it's easy.
Similar Threads - Water Damage Camera Forum Date
Advice Needed: Possible Post Water Damage to R/C. Also, is this Camera "clicking" normal? Phantom 4 Pro Help Jan 29, 2017
P3P FOR SALE-WATER DAMAGE CAMERA WORKS Classifieds Sep 17, 2015
Standard Fresh Water Damage P3S Phantom 3 Help Jul 2, 2017
Salt Water Damage - Gimbal Phantom 4 Help Jun 1, 2017
Has anyone had DJI cover water damage? Phantom 4 Help Apr 2, 2017
