Walkera Gimbal Setup
Hi Guys
I know this has been covered elsewhere http://www.phantompilots.com/viewtopic.php?f=19&t=12421&start=10 but I am a complete newbie so just want to confirm where the black,red and white wire from the Naza multi Rotor F2 port (shown in the 5th pic down on above page) connects to on the Walkera Gimbal.
I found this pic but it deosn't make much sense to me! :shock:
A pic would be even more helpful!
Thanks in advance
On the NAZA, the wire should connect to the F2 port on the very bottom pin on the left as you're looking at the ports. On the gimbal, that same wire should connect to just the 'pit' pin nearest the V1 pot on the black panel of the gimbal. I've used it on a couple of quads and I've only ever needed one wire, no ground required.
Yep, worked just like you said but I'm using the stock FC40 camera and it just sits backwards and makes a whirring noise.
It's a weight issue I think so I'll play around adding some weights tomorrow! If anybody thinks it could be anthing else please let me know.
Thanks again Wattage!
BoguSlav
