Walkera G-2D Install on FC40
Discussion in 'Phantom FC40 Discussion' started by Fuji-Flyer, Oct 24, 2014.
  1. Fuji-Flyer
    Southern UK
    Received this Gimble and started install, I read a number of posts and watched Youtube before starting.
    Installed the unit to the FC40 and running with Aux power from the Phantom, this powers up the gimble and with adjustments on the gimble controller I get a stable level look forward position and stays as Phantom moves, success for this part.
    Now for the problem, connected the lower signal pin on the NAZAM in the Phantom to the outside pin of the gimble control PIT. Turning the pot on the Transmitter will show in calibration mode on the NAZAM software but the camera does pitch...
    I have NAZA settings for Gimble taken from one Youtube ??
    Gimble on Output Freq 400hz
    Pitch Max 0 Centre 0 Min -900
    Pitch Gain 20
    Pitch Control speed 20
    From one of the Youtube video (German) it shows top pin on NAZA to bottom pin on gimble but swapped and same result.
    Anyone got a picture of the connections both ends AND do I need to do any further adjustments ?
    Thanks in advance....
  2. Fuji-Flyer
    Southern UK
    After some further searching / experimenting I have now a fully working Gimble on the FC40 with a Hero3. Basically it was the NAZAM setup Gains = 0; Control Manual Speed = 2 and now I have Pitch 390 and -60 Unit works from looking forward to vertical down.
  3. 2014fc40
Similar Threads - Walkera Install FC40 Forum Date
Need help with Walkera Gimble install on FC40 Phantom FC40 Help Dec 13, 2015
Walkera G-2D Brushless Gimbal Install Phantom 1 Help Nov 3, 2015
Walkera G2D Install with no soldering Phantom FC40 Discussion Mar 23, 2015
Walkera installed!!some little help more Phantom FC40 Discussion Oct 30, 2014
Installation of Walkera g2d Phantom FC40 Discussion Oct 14, 2014
