Vision app reset
Flew phantom this morning on battery 1. Ehausted battery shut everything down changed to new one. Restarted and no vision through app, all indicators and tilt worked but no picture. Tried a third battery and changed to different phone but still the same. Is there are special way to shut down or start up to avoid this?
After downloading the latest app from the DJI website the vision is back. I have changed the battery and tried the app again and it seems to work. i am suing the Phantom for a special shoot tomorrow which will require two batteries so fingers crossed. I have a suspicion that if the Extender drops below anything below 80% the problem arises but I am not sure
4wd said:
You need do further testing, do you have an alternative device to try?
Delete the app entirely and re-install it.
If that doesn't help it may be you are needing a new wifi module.
Which WiFi module causes the black FPV screen? Is it the one internal to the Phantom or is it the repeater?
-Scott
I think it is the repeater I shall do more test at the weekend
-Scott
This one
viewtopic.php?f=27&t=20006
Changing it doesn't seem to fix everyone's problems though.
BoguSlav
