I use a Nexus 7 with DJI Vision app ver. 1.0.36 and suddenly the app's radar function is showing my P2V's heading more than 90 degrees incorrect in the CW direction. I say 'suddenly' because two weeks ago the heading was correct with the P2V. This is important to me because I lose P2V orientation when it gets about 400 feet away from the home point.
I have a second Nexus 7-2 with app ver. 1.0.38 and it is showing the same incorrect heading. (Neither Nexus has an internal compass.) My search of the forum turned up one other user that had this same issue and it was suggested it was his phone causing the problem. Unfortunately, that was the end of that thread.
I received my P2V on 1 Dec. 2013 and I have all of the firmware updates installed. In spite of my having crashed my P2V four times, everything on the P2V is still functioning OK (The biggest issue was chipped/broken props which were replaced with new ones). During my troubleshooting on this problem, I have re-calibrated the compass many times, tested with two different versions of the Vision app on two different Nexus 7's, changed batteries in my RC, made sure my 5.3 amp LiPo batteries and the Range Extender battery were freshly charged for each flight, I have taken the P2V shell off and inspected all of the connections inside the chassis, and made sure the camera is functioning correct in gimbal movement, taking pictures and taking videos and I have no problem with WiFi connections.
:roll: At this point, I am about out of 'guesses' and would appreciate any suggestions pertaining to a solution to this problem!
Thanks,
ChesterT
Thanks,
ChesterT
