vision 2+ CRASH
Discussion in 'Phantom 2 Vision + Discussion' started by cooter, May 16, 2014.
  1. cooter
    I crashed into some bushes last night and when I pulled it out of the bushes it was tangles up in some briers and had to cut out. checked it over and it flew fine, but the camera would not work and after closer inspection noticed the camera was flopping around uncontrollably. Then I turned everything back off and restarted it and got the same results. Any Ideas as to what should do?
  2. denofr
    The first and easiest thing to do is to check the ribbon cables, make sure they are all connected.
  3. Aqeel200
    i really got to think of a way to protect the ribbon in case of a cut/damaged ribbon.
  4. cooter
    Exactly how would I check the ribbon cables? Do I need to remove covering? I'm not a very tech guy that tinkers with that kind of stuff. That is why I bought a out of the box ready to fly drone. LOL!
  5. DrJoe
    Sounds broke. Send it in for repair if your not a tech guy. Even if you are, there are no parts available for DIY repairs.
Similar Threads - vision CRASH Forum Date
dji phantom 2 vision plus crash Landing on 12000ft Phantom 2 Vision + Help Aug 4, 2017
Advanced Crash - Camera - No vision Phantom 3 Help Jun 16, 2017
Helpful hints: Phantom Vision 2+: water crash, PC connection, IMU calibration General Discussion Jun 9, 2015
Phantom 2 vision unstable flight and then crash Phantom 2 Vision Help Mar 31, 2015
Phantom 2 Vision + problem(s) after crash... Phantom 2 Vision + Help Mar 19, 2015
