Jacobrichards91 said:That sounds a little difficult, the vision 2 runs off of 5.8ghz for the controls and 2.4ghz for the wifi video. if you did add a 3rd party transmitter, you would need to do 900mhz or 1.2ghz. they dont necessarily transmit good quality (usually black and white). My suggestion would be to ditch the iphone, and install a 2.4ghz fpv and then mount a small screen on your controller.
Ok.but how can I connect video signal to transmitter from vision camera?Jacobrichards91 said:you can get one transmitter and two receivers. as long as you have the same channel for both receivers (usually there are 8 channels) then you can see the video feed on both!
Jacobrichards91 said:you see that cable coming out of the back of the vision 2 camera (it looks like a headphone cable). thats your video feed. if you buy this cord (link at the bottom) you can hook up your FPV transmitter, (plus power from the inside).
cable-
http://www.uavdirect.com/DJI-Phantom-2- ... p2v-cp.htm
jimre said:Or you could just connect an HDMI cable from your iPhone to your video equipment...
cable-
