Hi all,
I've had my P4 for about three months, started noticing some vertical lines in bright cloud and white objects like boats cars, and noise in shadow area. First thought it might be the camera settings, played with them, bought and used filters, had some great footage spoilt with this problem, ended up contacting the store I purchased it from ( I live quite remote so is not as easy as it sounds) and talked to them on the problem and the things I had done to try to resolve the problem. They organised the return of the P4 with some footage of the first vids shot with it and some recent ones.
They replaced my P4 straight away and told me there was a problem with a sensor in the camera.
The new P4 footage is perfect and so simple to set the camera on manual now and just leave ( find the Polarpro ND8-PL Filter great during the day ).
Anyway thought I would share the problem and result's with you all in the hope that if someone else is having the same issue it might help them out and stop them spending months as I did trying to adjust and reset things thinking it was something I was doing.
There are obviously going to be faulty cameras out there, and if you look close enough at the very first vid shot with it you can just make out the beginning's of it, it steadily got worse.
ps, the problem was barely noticeable when the vid was rendered and compressed up until the last couple of weeks where it was even noticeable in the post rendered footage.
Cheers.
Cheers.
