Try switching between h.265/h.264 and PAL/NTSC, especially the later. Note you can only get 1080 in 120fps and at least on mine it looks pretty ****...I cant get 120fps up on the controller - P4 Pro+.
Max is 50fps in any setting. 1920x1080 included. Is it the card that came with the drone or me?
Thanks.
Thanks for that. I can get 120fps in NTSC but not in PAL. Anyone else using PAL? Can you get 120fps?Try switching between h.265/h.264 and PAL/NTSC, especially the later. Note you can only get 1080 in 120fps and at least on mine it looks pretty ****...
Yeah, like I figured... I'm in PAL region but shoot NTSC anyway because i prefer the look I get with 30fps. The files are really the same, just a different set of fps offered. I guess 120fps does not fall under PAL and the Phantom does not offer 100 fps which would. But again, it doesn't really matter, just switch to NTSC whenever you want to shoot at NTSC framerates like 30, 60 and 120...Thanks for that. I can get 120fps in NTSC but not in PAL. Anyone else using PAL? Can you get 120fps?
