Vibration Absorber
Discussion in 'Phantom 2 Vision + Help' started by TomWolves, Dec 12, 2014.
  1. TomWolves
    Hello all!, I was looking at the "vibration absorber" on my phantom 2 vision plus and I noticed there is only two anti-drop-kit pins, one in front and one in back.My question is shouldn't there be four?Thanks for your advise
    TW
  2. PhantomFanatic
    USA, GA
    I have the P2 non-vision, but my gimbal came with four. I would think yours should have four.
  3. Meta4
    Meta4 Moderator
    Staff Member
    No ... two is standard. That's all they need.
    The anti-drop pins are only there to hold things together if something comes adrift.
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    If you want extra protection, you can loosely attach two plastic zip ties in the other two holes.
  5. TomWolves
    Okay then, I will leave it at two . I appreciate both your inputs thank you .
    msinger how do you like your gimbal protector ? What other goodies do you have to protect the gimbal? [WINKING FACE]
  6. davisual
    I got a package of replacement rubber damping pads and in the package there were the regular one's and firmer ones as well. Has any one used the firmer ones? Which is best? My wife says firmer is always better :)
  7. Larry L
    Copperas Cove, Texas
    2 is correct & ditto what msinger said regarding the zip ties.
Similar Threads - Vibration Absorber Forum Date
Phantom 4 Vibration Absorbers Set Install Directions?? Phantom 4 Discussion Apr 8, 2016
Professional Vibration Absorbers Phantom 3 Help Aug 19, 2015
P4 Advanced Video Vibration Phantom 4 Pro Help Aug 8, 2017
Stability Issue (vibration in the picture) Phantom 4 Pro Help Jun 13, 2017
gimbal vibration after update cant calibrate Phantom 4 Pro Discussion Jun 10, 2017
