Very slow GPS acquisition in mountainous terrain
Discussion in 'Phantom 1 Help' started by FrankB, Jun 19, 2013.
  1. FrankB
    Does anyone else have this problem: when operating the Phantom in valley areas in mountainous terrain, it takes forever to acquire a GPS fix and Home Location. My normal GPS (Garmin 76 CSx) works fine- acquires a position in a couple of minutes.
    A related question: with how many red GPS lights (none, 1, 2 or 3) can the Phantom be safely launched and be reasonably assured of coming back to its Home location if something goes wrong?
    Second related question: will the Phantom GPS eventually be upgraded so that it can make use of the Russian GLONASS GPS satellite network? This would definitely greatly improve getting a GPS position fix.
    Anyway, any advice or insights would be appreciated.
  2. Gizmo3000
    Sherman Oaks, CA
    When you see the 20x green blinks it's good to go.
    tho unsure what happens if Satellite signals are lost while in flight.
  3. BruceTS
    Granada Hills CA
    Very normal to have bad GPS lock in that type of terrain, even if you added the GLONASS network to the mix. you might want to try the upgraded V2 GPS and have it mounted outside the shell.
Similar Threads - Very slow GPS Forum Date
Litchi App -> Gimbal dial very slow Pro/Adv Discussion Dec 2, 2016
So,..Litchi uploads Very Slowly to Healthy Drones app on my iPad mini 4. General Discussion May 27, 2016
Litchi Panorama mission - VERY slow, high battery usage? Pro/Adv Discussion May 20, 2016
problem with phantom - props turning very slowly on turn on Phantom 1 Help Jan 31, 2014
Video DL very slow or locked up... Phantom 2 Vision Discussion Nov 24, 2013
