Very odd control issue
Discussion in 'Phantom 2 Discussion' started by Xanadu, Jul 2, 2014.
  1. Xanadu
    Craft:
    P2/H3-3D/iosd/irc 600mw tx/stock controller
    Problem:
    I have just started to notice that while flying (in GPS mode) giving commands with the right stick the P2 will sometimes pause and level out in mid air as if I returned the right stick to the center (which I do not). If I continue to hold the right stick in the direction I want to go it will resume the path. It only does this occasionally and for maybe a half second or so at a time.
    I have flown this setup for close to 7 months with no real problems.
    Thanks!
    Landon
  2. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    Sounds like something may be interrupting or interfering with the controller TX. Do you see any change in the lights at the time? Do they turn yellow?
  3. syotr
    Maybe a potentiometer going bad. Connect to the assistant and check that your sticks are communicating smoothly. Also check the s1 switch. Bad connection might make it switch to Atti mode intermittently.
  4. EMCSQUAR
    N 44.895 W 93.354 Minnesota
    Go into assistant software -> Basic -> RC and recalibrate your sticks. Then do an advanced IMU calibration.
  5. Xanadu
    Didn't fly today but I'll check all of these things and report back. Thank you so much for the helpful ideas!
Similar Threads - Very odd control Forum Date
Very Odd Artifacts Pro/Adv Discussion May 11, 2017
Very odd anomaly in flight data. Pro/Adv Discussion May 31, 2015
One Motor Won't Spin Up - Very Odd LED/Beep Indicators Phantom 2 Help Jan 19, 2015
Another idiot screwing it up for everybody General Discussion Today at 10:45 AM
Everything ok here to discuss? Off Topic Aug 3, 2017
