Vertical Photographs
Discussion in 'Phantom 2 Vision Discussion' started by rockville, Mar 21, 2014.
  1. rockville
    Still deciding what set up to buy and help would be appreciated.
    I looked at the Gopro 3 with the Zenmuse gimbal but the vision seems a simpler proven all round solution. Apart from having fun with it taking videos etc I need to take a series of images pointing straight down to combine and overlay over OS maps.
    Can the camera point vertically down? The main reason I moved from the idea of the Gopro was the lens distortion of the super wide lens, though rumour has it the Gopro 4 is going to have interchangeable lenses. How does the Vision cam images look after they are corrected?
  2. Pull_Up
    South Oxfordshire, UK
    The stock camera cannot be pitched down to vertical. The only way is to retro-fit a third-party brushless gimbal like Rotorpixel or Dronexpert (both plug and play) or 3D Power (requires soldering and some basic electronics/electrical experience).
    Also depending on how far up you intend to go to get your overlay note to stay legal in the UK you must keep the aircraft in unaided visual sight - which in most conditions is going to be an absolute max of about 1000ft in ideal conditions.
  3. SlackerATX
    Austin, TX
    The fish eye effect is pretty significant with the P2V, There is a lens profile for adobe and I think looks excellent after corrected.
    https://www.youtube.com/watch?v=fbiKe86qbLA
    The default center on the vision stock "gimbal" points well below the horizon line. Way too low in my opinion, but after lens correction there is almost nothing above the horizon left because it crops it. Good news it's is really simple to expand the range up and down of the stock gimbal and move the center higher on the horizon. Since I made those changes I'm really happy with the final video.
  4. rockville
    Thanks for the replies, if it cannot point straight down I will need to look at an alternative gimbal, correcting distortion
    In photoshop I've heard gives excellent results. I shall be using the final picture to show boundaries so the pointing down at 90deg from horizontal is essential. Maybe the Phantom 2 with a gimbal and another camera may be the best option.
Similar Threads - Vertical Photographs Forum Date
parallel vertical bar artifacts in bright areas!??? Phantom 4 Discussion Aug 5, 2017
Litchi: Fly Vertical Arc? Software Jul 30, 2017
Advanced Vertical Gimbal Tilt Not Responding to Touch Phantom 3 Help Jul 20, 2017
Vertical lines and dots on videos and photos General Discussion Jun 28, 2017
'Programming' a vertical only path.. is it possible? Phantom 4 Pro Help Jun 24, 2017
