Verizon Ellipsis 8 go app install problems
Discussion in 'Pro/Adv Discussion' started by Jason Lawrence, Dec 8, 2015.
  1. Jason Lawrence
    I hope someone can help...My tablet prompted me to update to Lollipop 5.1.1, so I did. Upon completion go app was removed, now I can download it but it will not install and I have turned off security settings regarding apps.....Help!
  2. bbfpv
    Long Island, NY
    no OS upgrade will remove previously installed apps. what error are you seeing?
  3. Jason Lawrence
    Everything was working fine...I did aircraft firmware update, go app prompted me to update radio, all was well. Then after I was all done with DJI updates, my tablet prompted update so I did it...upon completion go app disappeared. I downloaded current version from DJI with no issues,then hit install and tablet thinks for awhile then say application not installed. When I go to google play store it says not compatible with your device...until now I have been using this tablet for months with no problems...
  4. bbfpv
    Long Island, NY
    uninstall the app, remove the DJI folder and remaining contents, try side loading again w/ the version from the website.
  5. Jason Lawrence
    I performed a factory reset...when I look in application manager there is nothing related to DJI. I just downloaded go app fro DJI site, same result. It downloads but will not install.
  6. bbfpv
    Long Island, NY
    google the exact error message and see if you can find a solution.
  7. Jason Lawrence
    I have an update: I went to my local Verizon store and presented my case...They said it's a problem with the APP as when you go to the play store it now tells me it's not compatible with the device. After waiting on hold with DJI, they told me that's correct, the APP is no longer compatible with your device after update. They told me new OS on tablet uses too much memory and CPU power and is now inadequate for go app. New tablet only option. WTF?
  8. bbfpv
    Long Island, NY
    so wait, upon trying to install the app, it does a scan to determine how much memory and CPU is available at the time of installation? I call bullshit. Either way, you don't need a new tablet. Root your device and install a different ROM starting w/ the stock version of whatever you were using when it worked. There are tons of instructions on how to root all over the interwebs. Beats buying a new tab.
Similar Threads - Verizon Ellipsis app Forum Date
Got my Verizon Ellipsis 8 to work with the DJI App, now need tablet mount…. Phantom 2 Vision Help Apr 7, 2017
DJI Vision App on Verizon Ellipsis Tablet Phantom 2 Vision Help Jul 21, 2014
Verizon Ellipsis Tablet Phantom 4 Help Sep 3, 2016
Verizon Ellipsis 10" 4G LTE tablet :) Pro/Adv Discussion Apr 30, 2016
For sale Verizon ellipsis 8 tablet with Speck case Classifieds Feb 23, 2016
