Veering to left when full throttle ascend
Discussion in 'Standard/4k Discussion' started by Procharged97, Apr 19, 2016.
  1. Procharged97
    Canterbury, CT
    So tonight I wanted to run a battery down so I setup in backyard and got ready to fly. After it was safe to fly I hovered a bit then just starting flying back and fourth no higher than 10 feet off the ground.....about 9min into my flight I did a full throttle ascend and when I did this it veered to left about 6-8 feet while going up.......I tried again and it kept doing the same thing. I have done this before and it has never veered like that....if I ascend slowly it stays straight. Has this happened to anyone before?????. It worries me
  2. captainmilehigh
    Northeast Florida
    That's wild. I wonder if it could be a bad/bent prop. Maybe swap props (corner to corner) and see if it drifts right.?? Just a guess. Please keep us informed of your findings. Thanks.
  3. Procharged97
    Canterbury, CT
    Thats a good idea i'll try that. The props I used are brand new and I just balanced them...I RIT dyed them and one did feel weird when putting it on
  4. mdowney58
    Mountain City, TN
    And also check to make sure your motor screws are all tightened.
    Sent from my SM-N910V using Tapatalk
    Procharged97 likes this.
  5. Procharged97
    Canterbury, CT
    Checked screws, those are good. Going to try RC calibration then test it....then I'll try my original props...im hoping it was a fluke
  6. Mr. Pina Colada
    Mine when going about 50% full speed forward turns to the left, from what I understand this is a prop balance issue? Have not purchased a prop balancer yet so I have unbalanced props.
  7. Procharged97
    Canterbury, CT
    The props I used were balanced.....first flight was great...next day it would veer...I checked balance again and it was fine..I calibrated the rc and am going to test again with 3 other sets of props. Check out walmart.com for prop balancers...i got a really good one for $23 when other places wanted $45 for the same one
  8. Procharged97
    Canterbury, CT
    Try doing the rc calibration...you dont need the air craft on to do it..just rc and app...really easy and quick to do..might be worth a shot to see if it will fix your problem
  9. 10X
    10X
    Link ?
  10. Procharged97
    Canterbury, CT
  11. Ohiowoodsman
    USA
    Sounds like a bad compass calibration
  12. Procharged97
    Canterbury, CT
    Looks like the RC stick calibration worked. Tried with all my props and all is good. Thanks for all the suggestions guys!
    captainmilehigh likes this.
  13. captainmilehigh
    Northeast Florida
    That's good to hear. I'll have to remember that fix if mine starts to wander.
Similar Threads - Veering left full Forum Date
craft veering to the right General Discussion Sep 25, 2013
Left stick not calibrating Standard/4k Discussion Aug 10, 2017
Professional RC's far left LED blinking green Phantom 3 Help Aug 6, 2017
Standard Camera swings left periodically Phantom 3 Help Jul 30, 2017
Professional Phantom 3 Pro Camera Not leveled and looking left Phantom 3 Help Jul 29, 2017
