Hello everyone,
I just got my vision plus the other day and have noticed when I yaw the quad, it drifts away for about 8 feet. Then when I return the quad to the direction it was facing before, it drifts back to where it was. I also does the same thing when I use the yaw in the opposite direction. I have also noticed that sometimes the craft might “jitter” after the yaw is released.
I also noticed that after flying it for a while the drift gets lessens.
I also have a PH2 but that one does not have any drifts and it is very solid.
Hoping someone has seen this behavior before and can help.
Here is some more info;
The firmware is the lasted v3.06
My compass values are within range and the quad calibrates fine.
I have done basic and advanced calibration.
I have also calibrated the transmitter through the RC app and then through the assistant.
The yaw adjustment was another thing I did with no luck.
I also swapped out the compass with no luck.
Everything else works fine.
Any suggestions?
Any suggestions?
