will it work the same overseas as it does in uk ?
i know it will get GPS but what about int std codes to reply via txt ?
I believe it will. I used one but never left the country. I would personally call the Mfg and see if there are any settings you will need to change like the text tx format. I would make sure that the country code for where your cell service is current as well.will it work the same overseas as it does in uk ?
