  1. Phantomix
    Weston, MA
    I have a bunch of random antennas lying around my house that all use the same sma connector on my p4 controller, so could i use those for my controller to test them out? i dont remember anything about them i am just trying to find antennas with at least a 3000ft range that arent as annoying to setup as the itelite antennas and maxxrange
  2. flpholt
    palm harbor florida
    get a windsurfer
  3. Mark The Droner
  4. Phantomix
    Weston, MA
    what if they are for 5.8ghz or something else?
  5. Mark The Droner
    Then they won't work very well
  6. alokbhargava
    San Francisco, CA
    5.8ghz antennas will definitely not work.
    The other question is how do you really test if new antenna is able to push out power without having the right gadgets.
    Windsurfer is the easiest mod and also ensures it won't degrade the performance.
  7. Phantomix
    Weston, MA
    you mean the ones you put on the stock antennas? i have the itelite and maxxrange panel, i dont have the stock antennas anymore. the itelite panel is a true PITA to take off then put back on, then take off and put back on everytime i travel with it in my backpack. i just wanted something other than the panel so i can travel easier
  8. Improvedlight
    West Palm Beach
  9. John Locke
    Yorba Linda, CA
    Yes, it is a pita if you don't but a compatible backpack, one that accepts the itelite antenna installed on the RC. If you can't afford that then using a standard omni directional antenna with a wind surfer is your best bet. The problem is most wind surfers are made for the stock antenna. You might need to get creative.
    The pro craft and think tank helipak backpacks will accept the itelite antenna mounted on the RC.
Similar Threads - Using antennas Forum Date
Converting P3-4K to P3P Using New Board and Antennas? Standard/4k Discussion May 22, 2017
Using different type antennas together Phantom 2 Vision Help May 3, 2016
Using dual directional antennas on Wifi Extender Phantom FC40 Discussion Dec 31, 2014
Has anyone had any luck using the Pro+ Editor in the built in screen version of the P4+ Phantom 4 Discussion 9 minutes ago
Michigan- Three arrested for using drone to drop phone, drugs into Michigan prison. News Today at 6:40 PM
