Using GoPro and FC40 Camera at the same time
Discussion in 'Phantom 1 Discussion' started by Plabick, Jan 29, 2015.
  1. Plabick
    Is there any way I can mount my gopro for recording video and FC40 camera at the same time? I want FPV and GoPro at the same time. I am looking for something like a side by side mount for the cams. If it is possible, I don't want it to make it so I can't fit it in my case with the mount on.
    Thanks so much
  2. CactusJackSlade
    Sure, you will just need to learn about a bit of wiring and FPV basics. You can use the mini USB port on the side of the GoPro for the video out, that goes to your video transmitter, which can be powered by tapping into your battery solder points inside your unit (or a small stand alone battery). Then you need some goggles or a receiver with a screen to view the downlink. Doing it yourself FPV setup has a bit of a learning curve, but you will be better off for it :)
Similar Threads - Using GoPro FC40 Forum Date
Recommended FPV setup using a GoPro and Phantom FC40 FPV (First Person View) Jul 28, 2014
P2 using a GoPro and H3D3 gimble - any way to record flight data Phantom 2 Help Oct 21, 2017
Quick vid using GoPro Studio with my NSX Photos and Video Feb 28, 2017
Tablet Holder - My Solution using GoPro Accessories Standard Jan 14, 2017
P3S tablet holder using GoPro mounts Standard May 8, 2016
