- Joined
- Aug 16, 2015
- Messages
- 2
- Reaction score
- 1
- Age
- 39
I was wondering if I can replace the 1080p camera on the Advanced with the 4K camera. Has anyone tried this or know if it works?
Me too. Same problem. I wonder if the camera disconnects from the gimbal easy or do I need the whole gimbal assembly?
Ned whole assembly as 4k has cooling fan for processorMe too. Same problem. I wonder if the camera disconnects from the gimbal easy or do I need the whole gimbal assembly?
Very interesting. Did you buy the part from a retailer, or a crashed Pro?i've swopped the main gimbal board on my p3 advanced. fitted a p3 pro board inc fan. left the camera as is and its now shooting in 4k. happy days
a crashed pro budVery interesting. Did you buy the part from a retailer, or a crashed Pro?
That's kind of what I thought. You moved your camera and gimbal parts over to the "board" from the pro? very nice!a crashed pro bud
yes mate. easy to do. You just have to watch you dont damage the ribbonThat's kind of what I thought. You moved your camera and gimbal parts over to the "board" from the pro? very nice!
I would assemble my camera, used now in the aircraft Pantom 4k, in the advanced model, I would like to know if it's possible, and also I'm worry about if this aircraft has problems, when I'll connecting his camera maybe it does not fly anymore.
Since I have the opportunity to test it before buy it? I would not damage my camera. can someone help me?
thank you and regards
I don't know about the Phantom 4k, but the Phantom Advanced firmware is specific to the gimbal control board / video processor (the part the SD card plugs into). You most likely cannot use the 4k gimbal control and processing board on the Advanced model. So, it you are talking about just putting the camera itself on an Advanced, that may be piossible. However, the camera (sensor) on the Advanced is superior to the sensor on the 4k. So, that would not be an upgrade.
Different sensor? Dont the 4k and advanced share the same sony EXMOR chip? Its the standard that runs the panasonic sensor.I don't know about the Phantom 4k, but the Phantom Advanced firmware is specific to the gimbal control board / video processor (the part the SD card plugs into). You most likely cannot use the 4k gimbal control and processing board on the Advanced model. So, it you are talking about just putting the camera itself on an Advanced, that may be piossible. However, the camera (sensor) on the Advanced is superior to the sensor on the 4k. So, that would not be an upgrade.
It's not possible to use the Phantom 3 4K's camera on P3A or P3P as explained in post #128 of this thread. Phantom 3 4K uses Wifi for video transmission just like P3S while P3A/P uses Lightbridge.I would assemble my camera, used now in the aircraft Pantom 4k, in the advanced model, I would like to know if it's possible, and also I'm worry about if this aircraft has problems, when I'll connecting his camera maybe it does not fly anymore.
