Use both Phantom2 Assistant AND Naza-M Assistant Software?
Discussion in 'Phantom 2 Vision + Discussion' started by bizrank, Jun 4, 2014.
  1. bizrank
    I have been using the Phantom 2 Vision+ Assistant software, and I know that I can switch between Phantom mode and Naza mode there. (I love the Course Lock in Naza mode!) However, there also exists a separate Naza-M Assistant software. Do you other Vision+ owners use the Naza-M sotware AND the Phantom 2 Vision+ Assistant? Both of them? I'm guessing the answer is no, but I'd love to have access to more adjustments (gimbal/camera angle, trim controls, etc.) if they are indeed available.
    Thanks,
    Bill
  2. nintendrone64
    Simi Valley, CA
    Re: Use both Phantom2 Assistant AND Naza-M Assistant Softwar
    No, your Phantom Vision+ does not even have a NAZA in it. Do not use the software to attempt to adjust "things" on your Vision +.
    Only use the Phantom Software.
  3. bizrank
    Thanks, nintendrone64--
    I'll definitely take your advice and not attempt to use the Naza-M software assistant.
    However, I'm not certain what you mean when you say "No, your Phantom Vision+ does not even have a NAZA in it." The Phantom 2 Assistant for the Vision+ allows you to switch between Phantom and Naza modes, correct?
  4. xgeek
    London, UK, Declination -1.2
    The Phantom 2 range have a Naza-M v2 inside. It does not have all the features that a stand-alone Naza-M v2 has and is a sort of lite version if you like. Hence why you can only configure it via the Phantom 2 assistant and not the Naza assistant.
  5. bizrank
    Yes, I understand. Many thanks!
Similar Threads - both Phantom2 Assistant Forum Date
Both the same price{500}Phantom2 vision+ or Phantom 3 standard? Phantom 2 Vision + Discussion Mar 15, 2016
P3 Firmware iPad mini 2 and iPhone 5s both crashed Firmware Jan 2, 2018
First day's photo at Bothwell Castle Photos and Video Dec 7, 2017
P3 SE - solution to switching between FCC and CE mode, I used both, and it works for sure! Phantom SE Nov 29, 2017
Unresponsive shutter button. Both on Phantom 4 Pro and Non Pro! Phantom 4 Pro Discussion Sep 30, 2017
