- Joined
- Oct 10, 2016
- Messages
- 6
- Reaction score
- 0
- Age
- 71
Good day to all of you and thanks for accepting me in this forum.
I went to fly this afternoon and after a regular check up ( read pre-flight ) I started to elevate the bird. After two minutes of flight, the bird started a descent by itself, tried to prevent it from doing this and land it to a safe place but no chance, I broke a prop on an hydro wire and down the drone went.
Fortunately, only the prop was damaged. When I repowered everything, It said '' firmware update required '' even though I repulse the update until proven safe and sound.
It must have been done through the IPad Dji Go application.
Now I have an Issue.
I can't connect to the burd through the remote. I have no battery level and no images. I installed the version 1.9 on the SD card ( formatted previously ) and inserted the Sd into the gimball but after four minutes, the bird stops flashing red-green for a solid red, ( the wait time was more than 20minutes )
I've done that more than four times without success. Did I tell you that I HATE UPDATES .......Now I am telling you.
Tried to roll back to 1.80 and I get the same reaction from the bird except that the text file says (( ABort same version on SD card as the bird )) update not completed.
I am soooo frustrated, I will make this guy NEVER update again..I swear.
