Upcoming Vacation/Traveling with P3
Discussion in 'Standard/4k Discussion' started by Goldsaum82, Jul 29, 2016.
  1. Goldsaum82
    As the title says, I will be traveling to the Oregon coast next Monday for vacation. I'm definitely planning on bringing my P3 in its travel case (carry on). That said, is it true I need to deplete the battery to 30% (or lower) beforehand? Other than that, any tips and/or advice?
  2. RodPad
    Pacific,NorthWet, 97031
    wow, nobody replied yet, I don't think it matters if you deplete the batteries or not, they just want those batteries in carry on. Somebody else should posts some info.
    If your flying, you must have travels laid out, where are some of your stops on the coast?
  3. Goldsaum82
    Thanks, RodPad. We'll be spending our week in Lincoln City.
  4. RodPad
  5. OrlyP
    Metro Manila, Philippines
    Whether the batteries' state of charge is being checked or not, I think it's just plain common sense to discharge the batteries to a safer level (20-30%) before you pack them for your flight. It would also help to put them in a LiPo bag.
  6. Goldsaum82
    Well, the only thing I won't have is a LiPo bag, but it doesn't look as if it's required by the FAA. In addition, I will be draining the battery down to 0%. According to United, his shouldn't be an issue.
  7. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The FAA does not require batteries to be discharged to a certain level. See more details about their requirements here.
  8. Plonkydonk
    I just bought a P3S on my recent vacation to Hawaii and had no trouble bringing it home to Australia as carry on. TSA didnt even blink at it. I know the airlines only have restrictions on lipo batteries above 100wh and the P3S is only 68wh
  9. JamesG2571
    Put your props in hold luggage just to be safe, I've seen some people have them taken off them as they could be used as a weapon. When j travelled from London to Milan I put the batteries in plastic zip lock bags and taped over the connector just to be safe and also depleted the batteries.
  10. RodPad
    Don't go to zero.:eek:
    Maybe set them to auto discharge in a day, two days before you leave?
    cfd701 likes this.
  11. Steve Warren
    Just pack a Quran in the case with your equipment to ensure TSA won't even look at it.
    Sputnik1779, mdowney58 and cfd701 like this.
  12. WilliamM
    Lancaster, Pa.
    They auto discharge to 50% for storage, I would think that's good.
  13. OrlyP
    Just don't travel when the batteries are still auto-discharging. The process generates some heat, which is normal and well-documented. But it may not be ideal for safety reasons when the batteries are packed/padded in your carry-on at 39,000 ft.
  14. RodPad
    Yeah, that was my thought, making the discharge time as short as possible.
    Added:
    Makes you wonder is it 24 hrs or less than 48?
    or
    Is it in based on an hour glass with rice?
  15. OrlyP
    The discharge time is relative to the initial state of charge. The documentation says it can take "up to 2 days". In other words, discharging from 100% to 60% will take longer than discharging from 80%.
  16. Fifty7
    Here comes the silly question. I go out and fly until the battery is at 50%. Is this the same as being auto discharged?
  17. WilliamM
    Lancaster, Pa.
    50% is 50%, no matter how it got there.
  18. OrlyP
    Pretty much the same result.
    The auto-discharge prevents premature ageing of the batteries by draining them down to a more stable state of charge. If you used the battery down to 66% or lower, the auto-discharge will no longer be triggered.
  19. Fifty7
    Thanks. Thought so but wanted to make sure. I have experience with discharging from my rc cars (mini-z) but this is my first "smart" battery.
  20. RodPad
    Hum, I guess this makes me think more, if you set it to Discharge in 2 days, so after say 48 hrs, with the battery at 100% how many hours or days would it take to complete the discharge?
Similar Threads - Upcoming Vacation Traveling Forum Date
Upcoming DJI Go 4 update Control (Go, Litchi, etc..) May 20, 2017
Upcoming Trip, Looking for Advice General Discussion May 1, 2017
Best upcoming black November/Friday deals for P3A Pro/Adv Discussion Nov 12, 2016
DJI's upcoming Wind 1 drone is rain & windproof Other DJI Multi-Rotors Aug 21, 2016
Upcoming FAA 107 certificate testing and certificate information General Discussion Jul 25, 2016
