This sequence is not referred to in the DJI manual, but from memory (I could be wrong) I think that the LED's flashing that sequence means that a Home Lock has not been acquired, perhaps insufficient GPS satellites detected.
Waylander
waylander thanks for the reply. This is the second p3p that I have had and have yet to be able to fix this issue. Even after 3 different calls with DJI the lights are still the same. For the first flight the indicators were normal. I recharged my battery, went out for a second flight and after warm up the lights switched to this pattern again and are consistent. I hope it's something easy that I'm missing but I can't seem to track it down
