unplugged during update
Discussion in 'Phantom 2 Vision + Help' started by RRiley0512, Nov 18, 2014.
  1. RRiley0512
    Accidently unplugged brand new out the box phantom vision 2 plus during update. What do I do next. How can I be sure that all is well if I try to update again? Thanks
  2. Damon
    Eastern Wa.
    All you can do is plug it back into Phantom Assistant and pray that you can see all of your components listed in the update page. If you can see them, and your not sure if the firmware was upgraded correctly. You can reinstall by left clicking on each components "Current Firmware" which is listed on the far right of each component.
    By left clicking it will pop up the upgrade screen. By clicking on "Upgrade" on bottom it will force a reinstall.
    Remember to let Phantom cool down after upgrades and hook it back up on a very level surface. Then go and do a Advanced Full IMU calibration.
    Then do a field compass calibration in field. Power cycle and let IMU initialize. Get your course lock green "fast green LEDs" and the your Home Point fast green LEDs. Launch to 15 feet and make sure its holding fairly tight position in hover, before flying around.
    Good luck.
  3. RRiley0512
    I think everything worked. Going for my first flight in a few. Thanks for your help.
Similar Threads - unplugged during update Forum Date
Hub Unplugged - Ok to Store Batteries on Hub? Phantom 4 Pro Help Aug 29, 2017
Unplugged 5.8 antenna Standard Feb 7, 2016
Pause to take photos during POI (djigo) or Orbit (litchi) Control (Go, Litchi, etc..) Friday at 3:46 PM
Erratic warnings during flight Phantom 4 Discussion Jan 10, 2018
NFZ during RTH question Pro/Adv Discussion Dec 28, 2017
