Universal Camera Mount for Phantom 2
Melbourne, Australia
I've updated my Phantom Vision mount for tripod cameras to fit the Phantom 2 fuselage and it is now available for sale on shapeways. This mount is suitable for cameras up to 150g and parts for it will be compatible with a heavier mount that I'm still refining.
Shapeways link
Optional GoPro attachment
Note that this mount is capable of carrying dual GoPros.
Development thread
Phantom Vision mounting in Shapeways White Strong & Flexible Nylon.
He says up to 150 grams. The rx100 is over 200, so it would have to wait for the next version he mentions.
Correct. I'm fairly sure the RX100's are in the 220g class, without a battery.
My heavy test camera is 390g and I won't be selling the stronger mount until it flies smoothly with stock gear. Fortunately that might be just around the corner. I'm testing a solution today.
Hey Monsieur... Just wanted to let you know I received the heavy lift version of this. Thank you for that.
Now would it be possiblie for you to create a plate which would allow the camera to tilt using the gopro mount...
Here is what I mean...
http://skypixel.org/post/75196946200
I hope the mount works well for you. I have had trouble printing over the last 2 weeks and I'm finally getting it resolved, but I have a sort of development plan for future versions. I plan on producing a gimbal like tilting mechanism, where the camera is seated the correct way up. It should be available in at most a couple of weeks.
Hey MA, got the heavier lift mount a couple of weeks ago but only had a chance to assemble it today.
It appears I got the wrong parts as the side pieces are to long to fit on the damper balls. See pic for more
Hi MA, I don't see how I could stretch them this far, here is the top view of these ...
Please note that in this picture the mount is using the DJI Vision dampeners, while you appear to be using another, proprietary type. I don't know how flexible yours are and I designed them with the Vision dampeners in mind. I do not know how or if you will be able to stretch yours far enough, nor do I know if the mount will work as designed with the incorrect parts.
See again the suggest mounting style in this image:
wkflysaphan4
