Underbody LED Specs
Discussion in 'Phantom 1 Help' started by asynchronism, Aug 8, 2013.
  1. asynchronism
    Sarasota, FL
    Does anyone know the specs for the red/green underbody LED's? I'm travelling this week, and wanted to order some replacements (different colors) before the weekend - didn't have time to take it apart before I left.
  2. jumanoc
    Leds are part of ESC (Electronic Speed Controller), so you have to buy it and they don't have other colors.
  3. asynchronism
    Sarasota, FL
    Interesting... guess I expected those to be little separate boards under the frosted housings. Still, I'm not afraid of some electronics surgery - they're getting swapped one way or another.
  4. natscape
    They are SMD LEDs so if you can get the same specs in different color and you have the tools to work with SMDs, then I think you can change them out.
    Found this photo on the web -
    [​IMG]
  5. Driffill
    It is possible, but you need quality equipment and a very steady hand!
    My question is why? If you want a port/starboard set up, just swap the ESCs around. If your hell bent on changing the colour, why not look at replacing the ESC (with better ones???) and just use/ make up your own LEDs (or 12v automotive LEDs) to colour the arms? Connect the power for the LEDs to the same connection on the board as the ESC.
  6. cbpagent72
    The wire length is different for the red esc and green esc. You're pretty much stuck wherever they are.
    Sent from my SPH-L720 using Tapatalk 2
  7. Audaciter
    Sunnyvale, California, USA
    I have red on the left, green on the right. I believe I only had to lengthen one.
  8. asynchronism
    Sarasota, FL
    Luckily, I have the tools and knowledge for circuit board surgery... not scared of that part. The "why" is this... I'm red/green colorblind. The lights are pretty, but really don't offer me much navigational assistance. Swapping one set to white or blue would me a huge difference for me.
    I've also convinced a couple friends to order Phantoms as well - be nice to have mine a little different.
    BTW - natscape, thanks for the pic!
    Whorls likes this.
  9. Audaciter
    That sounds like an awesome project. Definitely share some pics, when you can.
  10. Driffill
    That's fair enough, I was just wondering if it was purely for "looks".
    I'm the type of person who would do it for looks alone, and because one or two people would tell me its not possible lol.
    Have a look at the LEDs used on this item on eBay 281129538511. They look very similar to the ones on the ESC.
    The only other issue I see is some led colours use a different voltage to other led colours. Red and yellows are around 3.4v and blue, green, whites and a few other are 2.5v or so.
    You could swap to blue and yellow? Greens to blue (as in eBay link) and reds to yellow. I'll keep searching and see if I can't find you some bare LEDs to use.
  11. asynchronism
    Sarasota, FL
    Well, it's for looks, too... heh.
    That's an awesome idea, the auto parts stores around here have tons of those LED bulbs... cheap. I'm back home this week, will have to break it down and see what things look like. Definitely interested to see what the voltages on the different colors meter at.
  12. netphreak
    I was searching for the same info that you were, and then I just took a multimeter to the phantom. The Green ESCs have the voltage at 3.2 volts per LED, so you could use blue or white for that same LED without needing a resistor. The Red ESCs use 2.9 volts, so you could swap it with yellow or orange. I bought Blue PLCC 6 5050 LEDs off of ebay, and they work perfectly. I'll post pictures if you want.
  13. Audaciter
    Yes, definitely post some pictures. I think it's great ! now all you have to do is introduce some kind of sequencer. :D
  14. netphreak
    Blue in the back, regular red in the front.
    [​IMG]
  15. Audaciter
    It must really suck, going into work everyday.....What kind of hell project am I going to get stuck with today..... ;)
  16. deluge2
    Anyone capable of swapping out the surface mount LEDs can probably handle lengthening (or shortening) some wires.
    Steve
  17. hurseyc
    I don't want to go red side/green side with mine but I would love to be able to swap the red and green front to back.
    My brain just can't wrap around red not being the tail lights.
    Is there any reasonable way to do that without soldering, cutting or adding wire?
  18. Skylane765
    What are the differences of the red left and red right and green left and green right? So the boards are each different?
    Can. Red ESC be CCW and CW?
  19. Audaciter
    No, only from the factory, one of the leads that goes to the Naza M-1 ---M-4 inputs is a little bit longer.
    If you can solder and heat shrink 2 pieces of wire to extend one lead, you can change them any way you like.
    They are all capable of being CW or CCW just depending on how you connect your motor. If you connect the motor
    and it spins the wrong way, just change "any" two wires and it will reverse rotation.
    It is by spending time under the hood of your Phantom, that you will learn how everything works together. And if you
    see something you don't like. Change it !
  20. Audaciter
    And if it burns to the ground........ Post pics. ;)
Similar Threads - Underbody LED Specs Forum Date
Private property vs controlled airspace Rules and Regulations Today at 12:56 AM
check state of leds? General Discussion Yesterday at 6:46 PM
P3A RC Cyan led fix and I can't enter in camera view Pro/Adv Discussion Sunday at 12:10 PM
Disabled GPS and nothing... Phantom 4 Pro Discussion Saturday at 2:33 PM
RTH Failed Standard Wednesday at 9:39 PM
