UK Charger Power Cable Question
Thanks, I just nicked one with a 5amp fuse from a Playstation 3 that seems to be doing the trick for charging the remote at least ...
3 amp will do, rated for 720 watt in uk, charger is 70w i think.
Thanks, the P3A charger is 57 watts I believe. Would you suggest a 5 amp fuse is too high then?
Id always use minimum rating necessary, for safety reasons, but no one ever does lol.
Don't suppose anyone has a P3A with UK charger so they can check what fuse it has in it?
This is the sightly higher power P3P so should be 3amps
Reactions: CJD
cgarner1
