Thought I'd just share this:
I had a few bad experiences flying with a Phantom 2 in checked luggage where the case was opened and stuff jammed back in where it didn't go and the case was thrown around and treated roughly. The gimbal actually came off with a bent mount plate at one point.
I began a search for TSA approved locks that would fit and added a liberal amount of "FRAGILE" stickers.
The idea with the lock was to keep curious airport workers from casually opening up the case and mucking around with the contents (mostly concerned about small airports in foreign countries but it's always a risk), but still let the TSA do their job and not have locks cut if they wanted to inspect the case formally.
I settled on this lock after trying a bunch that didn't fit:
Master Lock 4688D TSA Accepted Cable Luggage Lock
http://www.amazon.com/dp/B000WO84Z2/ref=cm_sw_r_udp_awd_UyNXtb0TSY6V2
So far so good.
Hope that helps
So far so good.
Hope that helps
