  1. MichaelS
    Lynnwood, WA
    Hi,
    I'm trying to change the standard USB module to the HDMI version. I have no problem getting the white cover off with a 1.5MM hex wrench. The trouble is the three black Phillips screws that hold the circuit board in place. My #0 Phillips screwdriver just spins and does not make contact with the screw notch. Please help!
  2. Erised
    Canada
    You can puchase a precision screewdriver set for about 10 to 15 dollars. I'm dont know the size you need, could be a #00. Get a good set because cheap one's tend to strip the screw. The size of philiips on dji is probbably metric like a 1.2 or 1.8 or 2mm metric has many sizes.
    MichaelS likes this.
  3. MichaelS
    Lynnwood, WA
    What I really need is the exact tool I need to buy. Is it a JIS screwdriver? Anyone?
    #3 MichaelS, Apr 24, 2016
  4. WetDog
    No,it's a Phillips. Do what Erised mentions - get a decent set of small screwdrivers. You will wonder how you survived adulthood without them.
  5. mnewxcv
  6. sar104
    Los Alamos, NM.
    I used the precision Phillips screwdriver that came with my P2. That worked fine.
  7. CactusJackSlade
    NOTE OF CAUTION: do NOT over tighten the PCB mounting screws when you put it back together.... you will crack the screw /board mounting posts (ask me how I know!)
  8. MichaelS
    Lynnwood, WA
    Thanks Guys! It turns out I had a very cheap set of screwdrivers. I bought a "precision" set for 4 bucks and all is well. :)
  9. Justgregg
    Denver Colorado
    it a set of small torks...home depot has them
  10. MichaelS
    Lynnwood, WA
    No, it's a proper #0 Phillips.
  11. WetDog
    I'm sure you could fit a torx in there once or twice.....
    I do it all the time if I forget to put on my magnifiers.
  12. Cale262
    Alberta/Arizona
    You can never go wrong buying a good set of quality tools!
    Jack Ley and MichaelS like this.
  13. Jack Ley
    Not sure if you like using that "WIsh" website, but it's great for gadgets and what now, this is the micro tool set I got, and it was the best thing I ever got for working on my Phantom and my racing quads.
    Wish | micro screwdriver
  14. alokbhargava
    San Francisco, CA
    Also safely unlatch the ribbon cables, replace the cards, put back the cables and latch them again carefully.
  15. MichaelS
    Lynnwood, WA
    Yep, I did that. It's working great now.
  16. Erised
    Canada
    Michael, I just installed my HDMI module and all I get is no connection to the rc. So yours works ok?
    #16 Erised, May 4, 2016
  17. MichaelS
    Lynnwood, WA
    Well with your fingers it is kind of difficult to plug in the long ribbon cable. I managed it with my fat fingers but you might want to use a pair of tweezers to hold that cable to make sure it is all of the way inserted into the connector. Also the skinny black cable on the right and the left side have to be connected too.
  18. Erised
    Canada
    Yep done all that, even took the cover off to disconnect the hdmi port from the board and I got connection so the usb works but as soon as hdmi is connected it won't connect to the rc.
  19. MichaelS
    Lynnwood, WA
    Ok, I got immediate success with the USB, but I have not hooked up the HDMI yet because I don't have the cable to reach my TV. I certainly hope it works. I will keep you posted.
  20. MichaelS
    Lynnwood, WA
    Alrighty then, I found a cable and the HDMI works perfectly.
Similar Threads - Trying install HDMI Forum Date
I'm trying to install iOSD MK II on my Phantom 2 Phantom 2 Help Feb 11, 2014
Connection error when trying to view photos Standard Dec 16, 2017
What is an ACC1 error when trying to calibrate the IMU Phantom 4 Help Dec 15, 2017
River man - trying to make it down the river to the lake, maybe next time. Photos and Video Nov 9, 2017
Hi, all! New S1000+ Pilot Trying to Fly for the First Time. Introductions Oct 25, 2017
