Trouble moving camera with RC finger dial
Humboldt county, CA
somehow I am missing something important here, because I cannot seem to rotate the camera between forward horizontal and downward vertical (Birdseye ) using the finger toggle on the right side of the RC. When I use the finger toggle I am only able to adjust the manual camera exposure. Which appears on the screen. My gimbal says connected/normal. Also the button under the RC on left side, called C1 I believe definitely switches the camera from one position to the other. And otherwise the camera seems to operate normally.
Which mode are you using?
Haven't got my Phantom 4 yet, next week, but I have seen the C1 and C2 mentioned in a video, plus this in the manual - have you programmed it go from horizontal to vertical?
The dial on the left side controls the camera tilt position.
Thanks msinger, obvious oversight on my part. I customized c1and 2, and presumed that the left and right finger dials would switch as well. Sure enough, the left dial does the trick
cokersean20
