tri bladed props for p3s
It's possible, but DJI does not make tri-blade props. It would be best to stick with OEM DJI props. Any of the props listed here (including the carbon fiber reinforced props) can be used with the P3S.
is it possible to get tri bladed props for p3s? also, are carbon fiber props worth getting?
This is a common question here especially among new-comers.
Why do you think more blades are better?
More blades = less efficiency, so yes, a single blade prop would be best.
The need for 3 or more blades is based on the need.
Why were they needed?... Originally, to reduce disc diameter, when two-blade designs could not meet design requirements such as ground clearance for nose-mounted engine designs or fuselage clearance for wing-mounted engine designs. These are not 'issues' for the Phantoms.
DJI has tuned their propulsion systems down to the firmware in the ESCs.
Reactions: RodPad
another random question, if i have p3s, can i buy the camera that would go on the p34k and attach it to the p3s?
No. Only the P3S camera is compatible with the P3S.
wkflysaphan4
