To enable VPS calibration with Windows 10
DJI drivers for Assistant 2 are unsigned and blocked by Windows 10.
These steps will enable their use.
Windows 10: Disable Signed Driver Enforcement
How can I install drivers that are not digitally signed?
Windows 10 enforces driver signatures by default. This can be disabled to install drivers that are not digitally signed. Use the following steps to disable driver signature enforcement.
  1. Click the Start
    menu and select Settings.
  2. Click Update and Security.
  3. Click on Recovery.
  4. Click Restart now under Advanced Startup.
  5. Click Troubleshoot.
  6. Click Advanced options.
  7. Click Startup Settings.
  8. Click on Restart.
  9. On the Startup Settings screen press 7 or F7 to disable driver signature enforcement.
Your computer will restart and you will be able to install non-digitally signed drivers. If you restart your computer again the driver signature enforcement will be re-enabled.
Reactions: GMack
So with assistant 2 enabled I started the vision calibration;
completed forward facing
completed downward facing
no red square on screen to enable completion of rear facing system
the 2 small screens to the left are showing the visions from the leg cameras no blockage
Just no red square on screen, therefore unable to complete the process.
Anybody had this issue?
Bob
Old saying try, try again.
Works!
Vision calibration completed!
Other than the gimbal issue of being required before each flight, the only thing to be done is cosmetic.
This bird was bought as a parts or repair bare bird,it had crashed into a wall, body and legs broken, yaw arm and flat flex cable broken.
It now hovers and flys although weather has held us back from hitting the field to run a couple of battery's though it.
Heading across border to pickup parts for the P4P+ that ran in to a pole, it's body is in worse shape.
Still looking for the camera/3 in 1 cable to fix.
Bob
Pauos31
