chrisono said:i think he means flickering while flying into the sun?
if so you can make a small lens hood from gorilla tape or something like that
Uncle Meat said:chrisono said:i think he means flickering while flying into the sun?
Won't the lens hood be visible if you did this? I mean the lens on the GoPro is such a wide angle I would think it would "see" the hood pretty easily, no?
U.M.
rjf said:I just use the crop tool in imovie works fin for my needs.
IrishSights said:I have used a small thin plastic piece stuck to the top of the GoPro. I deliberately cut it big so that it could be seen in the FOV. Then using scissors kept clipping it back so it could just no longer could be seen. At present I have no filter attached. It has been successful for me in cutting out the prop shadow.
An ND filter will not stop prop shadow, jello maybe
shrill mute said:A lens hood is the answer. Really big ND filters will also work but are not the best solution. Alternatively, you can tilt the camera dwon so the props' shadows don't fall on the lens.
Super duper custom tape lens hood and a small ND filter:
poostik said:shrill mute said:A lens hood is the answer. Really big ND filters will also work but are not the best solution. Alternatively, you can tilt the camera dwon so the props' shadows don't fall on the lens.
****. that gopro has some miles on it.
do you have a gimbal? did you have to counterbalance yours?
shrill mute said:poostik said:shrill mute said:A lens hood is the answer. Really big ND filters will also work but are not the best solution. Alternatively, you can tilt the camera dwon so the props' shadows don't fall on the lens.
I have a Tarot T2d and a Zenmuse H3-3D.
No counterweight required.
Uncle Meat said:I've read more than a hand full of Zenmuse gimbals are ruined because of added lens filters without any thought to a counterweight?
shrill mute said:Uncle Meat said:I've read more than a hand full of Zenmuse gimbals are ruined because of added lens filters without any thought to a counterweight?
I've read posts about folks who were worried about that happening but haven't read a single post documenting that conjecture. Do you have any links?
The early H3-2Ds would go limp when a filter was used - that's a different thing.
Uncle Meat said:shrill mute said:Uncle Meat said:I've read more than a hand full of Zenmuse gimbals are ruined because of added lens filters without any thought to a counterweight?
I'll see if I can dig up some links. Funny that DJI even states in the Zenmuse manuals that adding ANYTHING to the Gopro is a no-no and can cause issues. I'll even go so far as to bet DJI would void the warranty on the gimbal if they knew there was added weight.
U.M.
This is right out of the manual...
Warning & Disclaimer
No adjusting or amending is allowed to the H3-2D!!!
Before use, make sure to mount the camera to gimbal first, and then mount the
gimbal to aircraft. After this, you can power on the gimbal.
H3-2D is specialized for Camera and Lens before it leaves the factory. Please mount your camera to H3-2D when
get it. No adjusting or amending is allowed to H3-2D. Do not modify or add any other component/device (such as
filter, lens hood, etc.) to the camera; make sure to use the original battery; otherwise it may end up with worse
performance or even internal malfunction.
