THANKS A LOT ALL of YOU.
I have compiled the ones I needed and are below. I am citing all of you guys. No plagirism !
· Read manual again
· My tip is fly it the first week without using the FPV. Concentrate on learning to fly the aircraft and learn the FPV stuff later
· Start out in beginner mode. Go up to 20 feet using auto-takeoff then the vertical stick, then land using auto-land, and watch exactly what it does. Then after a couple of times. do it manually, landing all the way to the ground. Shut off the props by holding the left-stick down for three seconds, never with CSC.
Then 40 feet. then 80 feet, etc. Then start flying laterally in open fields, very carefully, not over groups of people or property, etc.
But most of you know all this.
· 2. Calibrate your compass EVERYTIME before taking off
· 7. Be aware of orientation and maintain full control
To make it easier for yourself, take off with the aircraft oriented with the green lights facing yourself and the camera facing forward. This way, it will be much easier for you to know where the camera is pointed when you want to capture a video or photo. You can also turn on Course Lock to lock the camera's direction, making it even easier to fly and capture footage.
The DJI Phantom series are incredibly easy to use thanks to the integrated software and hardware and the smart functionality in the DJI GO app. However, you should still make sure to always have full control over your aircraft, even when using automatic functions such as auto-takeoff and auto-landing. Keep both hands on the control sticks to maintain control throughout each flight.
