Tips for Flying in Manual Mode ?
Discussion in 'Phantom 2 Discussion' started by Xrover, Jun 8, 2014.
  1. Xrover
    Los Angeles, Ca
    I figured it is a real good idea to practice flying the P2 in Manual Mode instead of the GPS modes. I should have done this from the beginning. If the GPS/Nav system has a failure, you can either crash or bring it down Old School.
    So I changed changed Switch S1 position 3 (Right side Switch bottom position) from Failsafe mode to to Manual Mode.
    I went out and did some practice flying at about an altitude of 100 feet. I switched from GPS mode or from Atti mode down to Manual Mode. I did this while it was in a hover or moving slow.
    As soon as it goes into Manual Mode, the P2 drops like a Rock and requires some good careful up throttle to get it to maintain altitude and not go into a death wobble.
    Any tips or tricks from experienced Manual Mode flyers on transitioning from a GPS controlled flight mode into full Manual Mode?
  2. EMCSQUAR
    N 44.895 W 93.354 Minnesota
    Before using your P2 for experiment, may I suggest you purchase a Hubsan 4x (they're $40) to practice manual mode on.
  3. Dalite
    Brunswick, GA. USA
    Start 2 to 3 errors high, and only switch into the manual mode while generating thrust. The throttle reverts to a more linear range where hover is likely above mid stick.
    At first, everything needs to start and end in a hover, as you are controlling momentum. For every stick movement, there needs to be a corrective movement to stop momentum and return to level flight, You are not aided by the NAZA in limiting tilt, so flips are possible; whether intentional or not. So is inverted flight, but not the negative pitch needed to control it.
    As you become more experienced, you can merely shift momentum to a new direction.
    There are a number of mini quads that can be flown inside or oin light wind that offer minimum stabilization options to help you get used to flying it all the time. Also, there are flight simulator programs for use with either a separate USB controller, or using the trainer port of some RC controllers.
  4. Xrover
    Los Angeles, Ca
    I have flown Full Size and RC Heli's and basically that is what it reminded me of. Both hands on sticks and 100% of your attention.
    I have the Futaba T8FGS Radio. I haven't checked to see if it can be plugged in to the PC and used with a simulator prog.
Similar Threads - Tips Flying Manual Forum Date
Manual Mode Flying Tips? General Discussion Apr 12, 2014
Hong Kong flying/location tips? rooftop/park access? Phantom 4 Discussion Jul 3, 2017
Drone flying experience - tips and info General Discussion Jun 29, 2017
FPV flying tips/techniques FPV (First Person View) Apr 1, 2017
Any tips for night flying/long exposure pics? Pro/Adv Discussion Jan 18, 2017
