Tilt problem with Zenmuse H3-2D GoPro Gimbal
Hi.
The H3-2D GoPro Gimbal is pointed down to the ground all the time or pointing up in the sky.
If I turn the screw under the RC ( I think it is called x3 ) it goes from max position to almost max position in the other direction. It is not possible for me to stop in the middle.
I try to open naza zenmuse software but I only get to the skip option before I am in the real software. In the Naza assistent software
everything works fine. Do I need to put in something in the Gimbal option there ?
The problem start after I change from my normal dji RC to a older dji RC ( the one where the throtle stick stay in the position you put it in ) I change RS because the other one broke.
I hope someone can help me.
Thanks a lot.
Morten
You need to calibrate your x2 (pitch lever) goto Assistant -> Basic -> RC - calibration is on right side
I had exactly the same only on the P2. Recalibrate as per the manual on the controller *and* the zenmuse and all will be well
cokersean20
