Tilt lever question
Discussion in 'Phantom 2 Vision + Discussion' started by Birds-iView, Mar 8, 2015.
  1. Birds-iView
    I have a tilt lever on my vision and got it calibrated etc. my problem is that when I open the app on my phone it no longer works. Only will tilt until i Fire up the app.
  2. flyNfrank
    Indy, USA
    The lever is meant for the Remote Controller. It wont do you much good on the vision.
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Why not?
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Birds-iView, you need to select the following setting in the Phantom Assistant in order to allow the lever to work while the DJI Vision app is connected:
      File size:
      89 KB
      303
  5. flyNfrank
    Indy, USA
    ....Why not?
    So I suppose you mounted a lever on your vision also? What is its function, how do you access it while in flight?
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I did. It tilts the camera. I access it with my finger in flight.
    Are you just messing around? :?
  7. Mori55
    NJ-USA
    As far as I know it won't work with the app on with the vision +.
    It will work with the standard vision. I never got it working with the plus , soon as the app turned it stopped. I just went and got the new controller.
  8. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I have the Vision+ and it works for me. You cannot control it with the lever AND the DJI Vision app at the same time though.
  9. Mori55
    NJ-USA
    Correct , this been gone over numerous times. That why a lot of us got the new controller.
  10. flyNfrank
    Indy, USA
    Yeah I'm messing with you only because I think you are missing the punch line. I'm trying to point out that the lever is not meant to be mounted on the quad.
  11. yrdbrd1
    At least you guys got the thumb wheel to work. I can't even get it to calibrate. What am I doing wrong here?
  12. PVFlyer
    Hong Kong
    If you meant a "rear" level on the RC transmitter, take a look of a FB post back in November 2014.
    https://www.facebook.com/fpvbooster/pho ... 02/?type=1
Similar Threads - Tilt lever question Forum Date
Controller Lever - Tilt Control Phantom 2 Discussion Oct 31, 2015
Gimbal Tilt Lever - Fully Functional? Phantom 2 Vision + Help Aug 1, 2015
Tilt lever Phantom 2 Vision Help Jun 16, 2015
Tilt control lever Phantom FC40 Discussion Jun 4, 2015
Zenmuse 3d with Futaba 14 Tilt Lever Phantom 2 Discussion Mar 11, 2015
